Old 05-23-2011, 07:03 PM
brandonc707 brandonc707 is offline
Default Which brakes on my 67 camaro?
I am starting to look into brakes for my first gen camaro. I have 18" wheels and want larger brakes to both help the car stop better and fill the wheel better. I basically street drive the car, looking at the cpp big brake kit or the c5 conversion that I have read about......
Any suggestions or advice would be much appreciated
I am ok for now with what I have, but want to do some homework so I know exactly what I want to do when I am ready. What are you street guys running?
Thanks in advance for your help!!
Old 05-23-2011, 07:14 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
I had C5 stuff on my 67. Loved it!
Curtis
Old 05-23-2011, 10:22 PM
DEIGuy38's Avatar
DEIGuy38 DEIGuy38 is offline
Default Kore 3
Call Tobin at Kore 3, he has alot of knowledge. I went with the C6Z51 set up. Haven't run the car yet but they fill up a 18" wheel pretty good.
Guy
68 Camaro, LS1 T56, DSE Speed Kit 2, DSE Quadralink, DSE Mini Tub, Forgelines, Vintage Air, Dakota Digital, GM Tilt Column, Corbeau Seats
2012 Dodge 3500 4x4 6.7L Diesel CCSB
Old 05-23-2011, 10:50 PM
JKnight JKnight is offline
Wouldn't waste your time or money with the CPP stuff. It's not bad, but won't help fill 18" wheels and is basically stock replacement performance. Feel free to price it out vs. Kore3, but you'll probably find the superiority of the C6 stuff is worth the additional cost. Benefits of a C5/C6 system for a street car are numerous. Good/Great performance, 13+" rotors help fill the wheels, diverse pad selections, rotor upgrade options, easy emergency roadside repair/parts replacement availability. When front and rear are used, they are a proven combination that will work together nicely.
If we're talking a bit more technical or track-focused...I don't know if most would consider the C6 rear brakes fully up to the task of track duty (depends on how hard you really use them or how much your car weighs), but the floating design will help if you do visit a track occasionally by limiting the pad knockback issue many of us have experienced with fixed caliper rear systems.
