Closed Thread
Old 05-24-2011, 10:44 AM
Radlark's Avatar
Radlark Radlark is offline
Default 1979 Malibu Wagon in SoCal $1100
I know its not PT but it can be done up in the same style, is my 1979 Wagon body is pretty straight, the drivers side fender was replaced (but it is from a 1982) the turn signal lever needs to be replaced, the gas gauge does not work (not sure if it is the sending unit or the gauge), the back hatch works all the glass is REALLY good all trim around windows are good. Has new ball joints and shocks, has a 305/350 that runs really good! It will pass CA smog NO PROBLEM!! The drivers side rear qtr has bondo in it, the car is equipped with A/C but it is not hooked up! Car fires up EVERY DAY and runs great does not over heat, it is located in SoCal (Perris)
OBO
Old 05-28-2011, 02:36 PM
Radlark's Avatar
$900!!!!!!!!!!!!!!!! can be made to look like attached (not mine OBVIOUSLY)
Closed Thread
