Old 05-27-2011, 05:27 AM
Default Quarter sailpanel seams. Lead filler or ???
Hey guys. I'd like to get some feedback on the need to lead the quarter sail panel seams. I've personally always thought lead there was the "right" way to go since I've seen a few over the years that have filler there that has cracked. I'm sure it probably depends on the usage of the car and how much stress is applied to the area. My quarters have now been replaced and I need to decide on this before it leaves the shop.
John
'71 Nova (Build thread)
FFR Roadster
Old 05-30-2011, 05:56 PM
absinthe absinthe is offline
There is a product called Dyna-glass that I used on my 67 Camaro. It is a fiberglass product that, according to several folks I trust, is being used instead of lead nowadays.
Old 05-30-2011, 06:59 PM
dhutton dhutton is offline
Frank at Prodigy recommended a carbon fiber based filler made by SEM called Carbo-Fil which I used with good results so far.
Don
Old 05-31-2011, 06:40 AM
Thanks guys for the info.
That sub looks awesome. I've got some places on my OEM sub that I need to fill/smooth and plan on using All-Metal. Hopefully it works.
John
FFR Roadster
Old 06-25-2011, 12:12 PM
Ron Fox's Avatar
Ron Fox Ron Fox is offline
What has everyone else used? This is an area of concern.
Thanks.
Ron
1969 Firebird, 4-speed Coupe
If GOD is for us, then who can be against us!
Old 06-25-2011, 12:21 PM
70rs's Avatar
70rs 70rs is offline
I would also like to know what has been used and is holding up ok still.
Many of the cars on this site get the snot beat out of them (Todd, Steve, James, Randy, Brian...just to name a few)
Would any of the owners of cars that see track time AND have had full quarter replacement care to comment? What type of filler was used and how is it holding up?
I personaly would like to hear from Randy, Brian or any other second gen owner.
Eric
Old 07-20-2011, 09:23 PM
Ron Fox's Avatar
What else did ever one use?
Is All-Metal good to use on the quarter section or will it crack?
Ron
Old 07-21-2011, 08:10 AM
brans72 brans72 is offline
I am gonna touch on this since a buddy helped me and can add pictures later if you would like. This is just our way, well my buddy hates filler and thinks the less the better , so we cut the top of the sail area off and fabbed a new piece to fit better quarter and roof out of 18 gauge metal, put about 14 slices in it to shape it and tacked one conrner and worked the metal all way down till was finished, then cleaned up with green rough 3m sand paper wheels and it looks great with very minimal filler need and should be stronger. This was our approach with each person doing it different ways. Brandon
Old 07-21-2011, 10:11 AM
If the factory put lead there you need to put it back! "Any" type of filler will show after the car has been driven and set out in the sun. Do it correctly and you'll never have a problem.
Jeff Allen
J2 Speed and Custom
Old 07-21-2011, 12:47 PM
70rs's Avatar
I would like to see pics of that. I need to swap both quarters and my roof.
Eric
