Old 05-30-2011, 03:40 PM
Flash68's Avatar
Flash68 Flash68 is offline
Default Camber: does this look right? (track video inside)
...videos from Willow Springs track day 2 weeks ago.
kep points:
-2.2* camber -- alignment done right before track day
Global West control arms
ATS AFX spindles
need further info?
We were surprised to not see more dynamic camber in this video. Any ideas?
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 05-30-2011, 05:23 PM
chicane's Avatar
chicane chicane is offline
Kinda hard to actually tell... from the vantage of the camera.
Just sitting still from that vantage... doesnt even show the static that you have dialed into it. But in motion... it does look as if the tire had enough camber in it to address body roll and the suspension compression.
You dont have any tire temps do ya ?
Old 05-30-2011, 05:31 PM
Track Junky's Avatar
Hard to tell, it looked square in the well..............the best way to measure would be with tire temps across the face of the tire......and on that note the worst way to find out is when your tire is bald on one side, lol.
Gaetano Cosentino
Old 05-30-2011, 05:37 PM
Flash68's Avatar
Yes tire temps were recorded throughout the day but that folder is in the car and I am not with said car. Will have them later tonight and will report back.
Thanks guys.
2014 4 tap Keezer
Old 05-31-2011, 08:39 PM
Flash68's Avatar
Ok got temps for you guys. CCW track.
1st session -- warmup
Left Front: Outside to Inside = 88* to 89*
Right Front: Outside to Inside = 100* to 100*
Left Rear: Outside to Inside = 87* to 89*
Right Rear: Outside to Inside = 114* to 110* to *103
2nd session -- litte faster
Left Front: Outside to Center to Inside = 100* to 107* to 108*
Right Front: Outside to Center to Inside = 117* to 116* to 113*
Left Rear: Outside to Inside = 105* to 109*
Right Rear: Outside to Inside = 108* to 106*
3rd or 4th session -- full boogie
Left Front: Outside to Inside = 100* to 106*
Right Front: Outside to Inside = 132* to 127*
Left Rear: Outside to Inside = 106* to 106*
Right Rear: Outside to Inside = 122* to 117*
Over the sessions we also gradually brought tire pressures down from 35 to 32 psi cold, and they were gaining about 5 psi per session.
Comments?
2014 4 tap Keezer
Old 05-31-2011, 09:20 PM
Hmmm.......first thing first, are you experiencing any under steer? If not, a little more neg. camber might help. When I ran 255/40's up front I ran -2.5 camber. Where are you at now?
Gaetano Cosentino
Old 05-31-2011, 09:56 PM
Flash68's Avatar
Yes there is some. And if you don't believe me, Mary P said after driving it at Marina "this thing pushes like a dump truck!"
Camber is now at -2.2*. We aligned it a few days before the track day.
2014 4 tap Keezer
Old 05-31-2011, 10:17 PM
I thought that was before the sway bar..
Old 05-31-2011, 10:19 PM
Flash68's Avatar
Nope. I've had the sway bar for every autoX and road course I've done.
I never thought the understeer was as bad as Mary thought, but what do I know? I have no baseline.
2014 4 tap Keezer
Old 05-31-2011, 10:29 PM
315's in the rear with 245's up front doesn't help but I know 275's in the rear are not an option for you.
What front and rear spring rates are you running? Adjustable shocks?
Gaetano Cosentino
