View Poll Results: How much space is there on each side of your rear wheel (b4 it rubs)?
3/8" 11 45.83%
5/8" 7 29.17%
7/8" 1 4.17%
1 3/16" 5 20.83%
Voters: 24. You may not vote on this poll
Old 06-11-2011, 07:36 AM
jocko124 jocko124 is offline
Default Rear Wheel Fitment
I recently purchased a set of wheels and I was wondering how well a rear wheel should "fill" the rear wheel well. I have 3/8" of space between the face of the wheel and my fender and 2" of space from the rear of the wheel to my frame. I am planning on narrowing the rear end, after which I will have 1 3/16" room on each side of the wheel. I am wondering how well other member's rear wheels fit?
Lee
1966 Cutlass
The difference between truth & fiction: fiction has to make sense.
Build Thread:
https://lateral-g.net/forums/showthread.php4?t=31963
Old 06-11-2011, 09:56 PM
wmhjr wmhjr is offline
Running 275s on 10" rims. Have VERY little clearance on the inside (frame) side. There is sometimes a slight rub. Probably have 1/2" on the outside, all after modifying my wheel houses. Only way for me to get more clearance would be to modify the frame.
Old 06-12-2011, 12:09 PM
rjsjea's Avatar
rjsjea rjsjea is offline
The guy who owns the shop your car it sitting in would be the guy to ask. Too much discrepancy between cars. I ask him random stuff all the time, hahahaha
RobS
71 Demon, AlterK - 4 link GenIII hemi conversion
66 Rambler Classic Wagon, LS conversion -Scott's IFS/4bar-bagged
Old 06-12-2011, 12:41 PM
He thinks 11's will fit!
Lee
1966 Cutlass
Build Thread:
Old 06-12-2011, 12:57 PM
Whoa! There must be WAY more room on the back end of those Olds! Don't forget, if you're going to participate in any autox or road events you'll get a little movement back there as you articulate the suspension. What works great while the car is stationary isn't exactly what you get when you start working the car out.
Old 06-12-2011, 01:13 PM
Agreed. But with the room I have back there I will still have a 1/2" on each side
Lee
1966 Cutlass
Build Thread:
Old 06-20-2011, 11:14 AM
Biodds Biodds is offline
There is alot more to this. The wheel probably won't hit at all but you need to be concerned with tire rub. This depends on what tire size you run and if you have stock rubber control arm bushings or heim joints or a watts link or panhard bar to prevent side movement of the frame and body. Also it matters how much roll stiffness your swaybars have to prevent body roll.
I usually try to obtain 1" clearance between the frame/wheel tub and the inner tire bulge. The outer tire bulge can be much closer to the lip on the fender- like 1/4" or less.
Picture a right hand turn from the drivers seat. The body leans to the left with the left side moving down and left in relation to the tire and the right side moving up and left. On the right side the clearances get wider at the frame and the body moving upward keeps the fender from rubbing. But, on the left side the frame moves closer to the tire. Especially at the top of the tire. More roll stiffness and less compliant bushings allow tighter clearances.
Paul Wilke DDS
'70 Buick GS, 462 Stage 2, FAST EZ EFI,
2004R, Baer Pro+, 17x12.5, 17x10.5 CCW, called 3GS
'70 Buick Skylark Time Trial Car needs a rebuild
'87 Buick TR, Car Craft RSE winner in '98
2007 C6 ZO6 Katech, Moton, Brembo
Old 06-30-2011, 03:58 PM
Thank you Paul, I will definitely take that into account.
Lee
1966 Cutlass
Build Thread:
Old 04-27-2012, 09:28 PM
GFRDH-04 GFRDH-04 is offline
Banned
I very much agree with your point of view
