Old 06-13-2011, 05:45 PM
bdahlg68's Avatar
bdahlg68 bdahlg68 is offline
Default Metal cleaning and prep for welding
What do you guys use to clean off any rust or paint or seam sealer before welding in panels? DA and 80 grit?
Brian
1968 Pontiac Firebird
1989 Ford Mustang
Old 06-13-2011, 10:17 PM
elitecustombody's Avatar
wire wheel, grinder,blasting,whatever works better in certain situations
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1998 GS400TT widebody
1969 Firebird
1979 Firebird LS3,DSE,Baer
1938 Dodge LC pickup
Old 06-14-2011, 07:34 PM
^^^^^^^^^ What Stefan said -- basically -- whatever works.... I've used dental picks.... screwdrivers...
IF you use wire wheels == PLEASE wear eye protection..... those things fly off with some serious velocity!
Old 06-14-2011, 10:30 PM
ErikLS2's Avatar
ErikLS2 ErikLS2 is offline
I know it's probably not typically used but DO NOT use a chlorinated brake cleaner and weld with anything using argon. The combination produces phosgene gas (which is far worse than what comes out of me after a Klondike bar).
Most everyone probably knows by now but just in case.
Erik
69 Camaro
