Old 06-15-2011, 05:51 PM
maro67 maro67 is offline
Default 1st gen Camaro subframe dimensions
It seems this is the most common dimensioned drawing for the 1st gen F-body cars. While this is a good reference, it seems there is some information missing.
Does anyone know the correct dimensions for the following:
-The distance from Body mount no.1 (firewall body mount) to center line of the front wheels / axle (at rest)
-The distance from Body mount no.1 (firewall body mount) to the radiator support mounts
-Does the datum used for the vertical dimensions represent the ground (assuming stock ride height and rims and tires)
-What is the vertical dimension from the datum line to the top of the front frame rail (radiator support mounting surface)
Old 06-16-2011, 10:10 PM
BonzoHansen's Avatar
BonzoHansen BonzoHansen is online now
any of this help?
http://www.pozziracing.com/Media/F_gen_Firebird_sub.jpg
Scott from NJ
