Old 06-17-2011, 07:37 PM
TheCntrion TheCntrion is offline
Default 414 SBC for sale Dart and AFR
MAKE ME AN OFFER, just keep it above the belt...
I have been holding onto these parts for a while because i was going to use them in a pro touring nova I am building. I decided to go with a big block, so these parts are now for sale. I am going to list all of the parts and the part numbers that will be included. An engine put together with these parts will easily make 550 hp and possibly 600 or more depending on how you put it together. the new cost of all of these parts if you bought them new would be about 14,000 dollars. i am only expecting to get half of the new cost of these parts.
the engine is currently disassembled and at my machine shop ready to be assembled to your specifications. that way you know what you are getting. the dome on these pistons can be cut down to flat tops so you can get the compression where you want it. these are all good parts and they have a lot of life left in them. i want this to be a quick sale so it is priced well.
short block:
dart little m block 4.125 bore steel caps part# 31132211
eagle forged crank 3.875 stroke 6.0 rod 350 mains
eagle forged h beam rods 6.0
pistons JE forged dome 182033
AFR 220 heads 65cc chambers not cnc ported
titanium Valves 5.040 length
titanium retainers
AFR stud girdle
comp cams gold race rockers
comp cams solid roller lifters
comp cams solid roller cam 12-923-9
jesel dry belt drive system 2 piece upper pulley
arp head studs
price of all parts together- 6500.00
call me at 858-869-9303 if you want to discuss the parts.- Adrian
Old 06-17-2011, 10:06 PM
SLO_Z28 SLO_Z28 is offline
Great deal for someone with more money than me GLWS, wish I had the coin for this.
Old 06-18-2011, 10:27 AM
i am torn between keeping the parts and selling them. im going to kick myself if i start a project next year that uses a small block. at the same time 6.5 will go a long way buying parts for my nova that i am building right now...
Old 06-23-2011, 12:58 PM
Make me an offer...
