Old 06-29-2011, 03:57 PM
RBR's Avatar
RBR RBR is offline
Default speed bleeders for wilwood dynalites?
Does any one have a part # for speed bleeders for these calipers. I've tried calling and got 1/8x27 npt as the threadsize. I can't seem to find any bleeders that match that threadsize?
Old 06-29-2011, 05:32 PM
64pontiac 64pontiac is offline
Russell Performance lists part number 639540 for wilwood, but its only a 1/4 thread size....... not for use with their dynapros I guess..... only thing I can find is wilwoods std bleeders.
Tyler
HPI Customs
Manitoba, Canada
www.hpicustoms.com
Old 06-29-2011, 05:33 PM
Once you go vacuum bleeder, you never go back.
Old 06-29-2011, 07:18 PM
osdmike's Avatar
osdmike osdmike is offline
Maybe the larger thread size Speed ​​Bleeders work well.
When I used the Speed ​​Bleeders for my Dynalites, I liked Them at first.
But the 1/4-28 thread size are so tiny, they clogged up after a while.
So I changed back to the original ones.
So for the Dynalites there is probably a better option.
Old 06-29-2011, 10:53 PM
RBR's Avatar
RBR RBR is offline
Thank's for the help
Old 06-30-2011, 07:31 AM
wmhjr wmhjr is offline
After all the experiences I've had with Russell plumbing components over the past year, I will no longer use anything from them. I also had them (speed bleeders) on the Performance Machine billet brakes on the Harley I built a few years ago. Ended up being more trouble than they were worth so they came off too.
Old 06-30-2011, 10:11 AM
RBR's Avatar
RBR RBR is offline
What about using Earls speed bleeders?
For harleys and dirt bikes I just add the fluid from the calipers back to the mastercylinder. I use a 60cc syringe with tubing. No bleeding needed. Doesn't work well for a car, too much volume.
Old 06-30-2011, 10:13 AM
RBR's Avatar
RBR RBR is offline
Do you use the small hand held bleeders or the big ones that look like a weed sprayer?
Old 06-30-2011, 10:18 AM
Big one that looks like a weed sprayer. Hook it up to the air compressor and sit back and fill the brake resorvoir. You can get one for like 30 bucks at harbor china that works great. Hardly any mess.......
