Old 07-09-2011, 12:41 PM
Xplosive Performance's Avatar
Xplosive Performance Xplosive Performance is offline
Default One Vehicle Fire Occurs on Average Every Two minutes H3R Fire Extinguishers Brackets
Research Shows One Vehicle Fire Occurs on Average Every Two Minutes
Larkspur, CA - According to the NFPA (National Fire Protection Association), U.S. fire departments respond to an average of one highway vehicle fire every two minutes. NFPA reports that more people died as a result of vehicle fires than apartment fires, and that most highway vehicle fires result from either mechanical or electrical problems. In fact, sixty-five percent of the highway vehicle fires began in the engine, running gear or wheel area.
H3R Fire Extinguishers & Mounting Brackets
In Chrome, Black, Red
1 lb or 2.5 lb
http://www.xplosiveperformance.com/F...ers_c_375.html
Clean agent extinguishers from H3R Performance.
These H3R Performance HalGuard fire extinguishers feature a clean agent--an electrically non-conducting liquid or gaseous fire-extinguishing agent that does not leave a residue.
  • No thermal shock to electronics
  • No mess or damage to vehicle or surfaces
  • Liquefied gas extinguishes hard-to-reach fires
  • Does not impair operator's vision
  • EPA approved
  • Listed and rated 1B:C by Underwriters Laboratories
  • Rechargeable
  • Made in U.S.A.
  • Steel strap & mounting bracket
  • 6' - 8' discharge range
  • High quality steel cylinders
  • All metal valve construction
  • Compact, lightweight, easy to use
  • One year limited warranty
H3R Performance hand held 1 lb. and 2.5 lb. fire extinguishers come standard with aviation style mounting brackets. Stylish and versatile billet mounting brackets are also available. Band clamps fit 2.6” or 3.0” diameter fire extinguishers, and can be combined with the flat surface mount or either of the four roll bar mounts. Available in polished and brushed finishes. One year limited warranty.
NHRA Approved
Protect your Car and be Ready should the Unthinkable Happen
PRICES STARTING AT
$259.85
Complete
Bottle and Mounting Brackets
Bob Brown
XP Motorsports LLC.
Xplosive Performance Inc.
[email protected]
AIM: CH3NO2fun
