Old 07-10-2011, 05:24 PM
g356gear's Avatar
g356gear g356gear is offline
Default 69 Camaro- Marquez driving LED lights issue.
Hey guys,
I hooked up my Marquez billet LED running/signal lights and when I ground them, the running light works perfect. The problem is that they don't seem to blink for the signal when it is engaged. Any ideas? There's nothing in the instructions from Marquez about this issue for troubleshooting. I did already upgrade to a heavy duty flasher under the dash for my rear LED tail lights and they work fine. Thanks.
69 SS396 Camaro Coupe, 4link, 12bolt posi, Speedtech LCA and UCA's, Hotchkis 2" drop springs and sway bar, Ridetech triple remote resevoir coilovers, Bilsteins, Wilwood 6 piston front/4 piston rear, Magnaflow stainless exhaust, Lemons Headers, Comp rollers/p-rods/cam, Fikse 18x8.5 and 18x10
Old 02-14-2015, 01:41 PM
jim_crawford jim_crawford is offline
Default I'm having the same problem?
Did you find a fix?
Old 02-14-2015, 07:08 PM
aany001's Avatar
aany001 aany001 is offline
Did you hook the ground up to the chassis of the light. The 2 wires are for a running light and the other flashes. I just tested mine the other night. I hope this helps.
