Old 07-14-2011, 12:09 AM
Ivan Vella Ivan Vella is offline
Default 6 piston calipers to suit CPP 13 inch rotor
Does anyone know of a 6 piston Caliper other than Wilwood that would suit the CPP 13" x 28mm rotor?
I really like the Wilwood calipers but in Australia it is extremely hard and expensive to get a vehicle insured or registered for public road use with them.
I have no problems making a custom caliper brackets or using calipers off another car and getting the reconditioned providing they are the right size/performance and look the part.
Any help would be greatly appreciated.
Ivan
Old 07-15-2011, 11:21 AM
groovyjay's Avatar
groovyjay groovyjay is offline
http://cgi.ebay.com/ebaymotors/09-10...item415993e45c
Would those work?
Old 07-18-2011, 06:32 PM
Are they the same ones that Kore 3 sells?
If they are they are designed for a 14 inch rotor so the braking surface won't line up with the caliper properly, also my rotors are 2mm thinner than what they are designed for so when the pads wears down to it's limit it is possible that the pistons could push out too far or run out of travel.
It sucks because I do like those calipers and they are legal in Australia because PBR make them which is an Australian company. (although it is still cheaper to buy them from America).
Old 07-20-2011, 12:55 PM
Apogee Apogee is offline
Why design your brakes around a proprietary (non-OE based) rotor like the one offered by CPP? If you're putting together a kit, it would seem like using an OE based rotor, no matter how obscure, would at least give you more options in the future should things change. The 1988-1996 C4 HD 13" x 1.1" [330 x 28mm] rotor might be a better alternative, although without knowing what you're trying to accomplish, it's a little tough to say.
Is a C5/C6 2-piston kit out of the question? What is driving the need/want for 6-piston calipers? Why a 13" rotor instead of 14"? What are your current (and future if applicable) wheel limitations?
Tobin
KORE3
www.kore3.com
