Old 07-29-2011, 06:03 AM
ccracin's Avatar
ccracin ccracin is offline
Default Stainless Welding
I'm not sure where to put this. Mods feel free to move it as needed. I am almost done fitting our fuel cell. It is made from 16ga 304SS. I will be TIG welding it together. My question for those of you that may have done this is do you back purge the welds with Argon? I know this is the "Best and Correct" thing to do, but it will take more investment in regulator, hose, time. I have done some test pieces and the back side of the welds are not "pretty", but look sound. When I metal finish the welds they look good with no porosity. My other thought would be to try some Hastaloy W TIG rod. This is a good "catch all" rod that may not be as picky as 308 rod. I just wanted to get some input. Thanks!
Chad
Instagram - @cctek
68 Chevy Pickup Project
Old 07-29-2011, 06:19 AM
There is a flux paste for stainless that you can brush onto the back so you don't need to back-gas it. I'll have to look it up - I have the docs at home in a welding folder....
Jim
My Project: 65 Porsche 356G
https://lateral-g.net/forums/showthread.php4?t=5109
Old 07-29-2011, 06:22 AM
ccracin's Avatar
Jim
Thanks buddy. I may have to take back my comment about the size of your...........welding table!
Chad
Instagram - @cctek
Solarflux
Old 07-29-2011, 06:55 AM
ccracin's Avatar
Little car, little welding table, HUGE socks, I'm just saying.
Ah....yea, well back to Solarflux. I looked the stuff up. Looks like a potential solution. My concern is the residue left behind inside the tank. I'm not sure if exposure to fuel continually would dissolve it and cause me problems. Whatcha think?
Chad
Instagram - @cctek
Old 07-29-2011, 07:12 AM
parsonsj parsonsj is offline
Default You really ought to back purge
On a fuel tank, you really ought to back purge. Too many things can go wrong when fuel drips or leaks, and all precautions should be taken. Free advice, and worth every penny!
John Parsons
Old 07-29-2011, 07:15 AM
ccracin's Avatar
Thanks John. We are getting a cost on a dual tap flow meter and hose. Hopefully it won't be too bad. We'll see.
Chad
Instagram - @cctek
Old 07-29-2011, 07:39 AM
I back purge with two cylinders and two flow meters. Something like this:
j
Having a second cylinder around really helps prevent the dreaded "run out of gas on Saturday afternoon" problem that can ruin a weekend.
John Parsons
Old 07-29-2011, 07:46 AM
ccracin's Avatar
Been there absolutely. We try to stay on top of it. 2 cylinders is on the list for sure though. What would you say to back purging with the cylinder I have on my MIG welder with 75/25?
Chad
Instagram - @cctek
Old 07-29-2011, 08:05 AM
Using CO2 (the 25 in 75/25) is controversial. The little nubbies you see on a non-back-purged SS weld are carbon based, and having CO2 present doesn't prevent them from forming, and increases the carbon content of the resultant weld, resulting in it being more brittle.
On the other hand, there are folks who claim it works well...
Your decision, but I don't do it. Argon all the way for me.
John Parsons
