Old 08-01-2011, 05:59 PM
69-er 69-er is offline
Default Types of 4-Link Suspensions
We have decided to go get rid of the leaf springs on the 69 Camaro and go with a 4-link setup. I've never examined one up close or installed one before.
I've seen "4-link" and "4-bar" systems. It looks like the 4 bar systems have equal length links while the 4 links are unequal. I understand unequal lengths are more desirable for wheel hop. This car won't be thrashed at the track, so the absolute best performance isn't necessary. Or is it?
Also, tire clearance is tight, width-wise, so I'm not too crazy on using a panhard bar. We really can't afford any side-to-side movement during suspension travel. Are there triangulated 4 links out there?
If anyone can point me in the right direction to get started on my rear suspension education, that would be great!
Old 08-01-2011, 06:20 PM
Rick D's Avatar
Rick D Rick D is offline
Welcome to the site, and this topic has been beaten to death. Try using the search at the top of the fourm. That should give you at least 2 days worth of reading. Also post up some pictures of your ride in the project section.
Rick
Old 08-01-2011, 08:01 PM
3_z28camaro's Avatar
3_z28camaro 3_z28camaro is offline
Two of the most popular and proven rear suspension setups are from DSE and AME. I will be using he Art Morrison rear setup since it replaces those weak stamped rear frame rails. Both are triangulated four link and very capable.
http://artmorrison.com/homepage.html
http://www.detroitspeed.com
1971 RS Camaro
Old 08-04-2011, 10:58 PM
Normally a 4 bar has very little adjustments where a 4 link has more.Have you looked at a 3 link or torque arm set up? Like http://www.speedtechperformance.com/...rod/prd170.htm or http://www.jakesrodshop.com/Products.html or a bolt in one https://securec20.ezhostingserver.co...id=25&catid=77
Old 08-06-2011, 05:37 PM
What's everybody's opinion on this?
http://cgi.ebay.com/ebaymotors/67-69...Q5fAccessories
How can it be so much cheaper than the others mentioned above? The guy has a lot of positive feedback.
Old 08-06-2011, 05:46 PM
Ron in SoCal's Avatar
^ that is a drag race set up. Really good for planting the rear on fast starts, not so good for going around corners.
Ron in SoCal
69 Camaro in progress
Old 08-06-2011, 05:47 PM
I read that 4 bars are considered more for street use, (corners) and 4 links were for drag racing.
Old 08-06-2011, 06:07 PM
You might be right, but that looks like a 4 link to me. Ask the seller his intended application, get some stats (AS%) and see what he says...
Ron in SoCal
Old 08-06-2011, 06:10 PM
Already did! What to you mean by "(AS%)"?
Old 08-06-2011, 06:12 PM
AS% = Anti Squat %
Ron in SoCal
