Old 08-02-2011, 09:09 PM
Twix27 Twix27 is offline
Default Not shifting to 3rd
My turbo 350 will not shift into 3rd gear and i have the kickdown cable set up right and the modulator valve is still good. Can't figure it out. =/
Old 08-03-2011, 08:49 AM
rchaskin's Avatar
rchaskin rchaskin is offline
Check plastic teeth on governor.
It is behind a round "knock on" cap on the side of the trans.
I had a similar situation years ago.
Mine would only go in first & reverse though.
I pulled the governor out and no teeth left at all.
Good Luck!
