Old 08-05-2011, 02:25 PM
smcox1 smcox1 is offline
Default 18" 9.5 C6 ZO6 rims
Can I put 18" 9.5" C6 ZO6 Rims on my 1976 camaro without putting mini tubs? Any help is greatly appreciated.
Old 08-05-2011, 05:11 PM
FadedSS FadedSS is offline
with the correct backspacing, the rear will fit no problem. a 9.5" in the front is going to be a very tight fit even with ideal backspacing, assuming you have stock width front suspension
Old 08-08-2011, 07:24 PM
Apogee Apogee is offline
It also depends on what size tire you intend to run...if you stick with something in the 26" diameter range and no wider than a 285, then I don't think you'll have any issues. You'll need to run a wheel adapter (bolt-on spacer) which you can use to get your backspacing spot-on...make sure you take your rear disc brakes into consideration when caculating your current track width if you have discs or plan on upgrading at the same time.
Is the plan to run the 18x9.5 front C6 Z06 wheels front and rear or do you have something else in mind?
Tobin
KORE3
www.kore3.com
Old 08-08-2011, 08:40 PM
I'm planning on running them front and back
Old 08-08-2011, 08:43 PM
And I just realized they are 8.5" and they are 275 40 r18 tires
Old 08-15-2011, 11:50 PM
If they're only 8.5" wide, then they're not C6 Z06 wheels...are they repros? If so, do they have the C6 Z06 offset or the base level C6 offset?
Tobin
KORE3
www.kore3.com
