Old 08-14-2011, 01:43 AM
Ivan Vella Ivan Vella is offline
Default oil pan to suit 69 Camaro
Hello,
Does anyone know if Milodon's 31505 Road/Race oil pan will fit a 69 Camaro with a Unisteer rack and pinion or know of a good oil pan to suit a SBC that has good baffling for circuit racing use.
Ivan
Old 08-14-2011, 09:44 AM
Track Junky's Avatar
I'm not familiar with the Unisteer Rack application. I will point out though that I run a Speed Direct Rack and am using a Canton road racing pan. The pan and rack are very close to each other and I have had to bend the equalization line to above the rack as opposed to directly in front of the pan which gave me about 3/16" clearance from pan to rack.
Gaetano Cosentino
