Old 08-15-2011, 08:29 AM
latzoo latzoo is offline
Default T56 install
About to begin the install of my LS1/T56 install on my 67 camaro. Any tips on shifters models, easy floor cutting, etc. My car was a previous column shift auto. Thanks.
Old 08-29-2011, 09:42 PM
DETON8R's Avatar
DETON8R DETON8R is offline
Default Engine Mounts and Trans type??? Stock Interior???
Might need to monkey around with the shifter location. Engine location (can be modified with engine mounts, most don't change that dimension unless you want to move the engine rearward), type of T56 (standard or Magnum) and the type of interior (stock console vs bare trans tunnel vs custom interior) will all make a difference. And you will need appropriate trans cross member, given the location of the engine. No easy answers here without more info.
Personally, I'm using a LS1 and T56 for a 1999 Camaro, and I'm swapping the '99 Camaro dash and console into my 1969 Camaro. The shifter is a PRO-5.0 that came with the T56. The shifter post is about 4 inches too far forward in the car for my set up, so I will need to relocate it with an off the shelf aftermarket solution, or custom brackets, or a "bent handle" shifter (the shifter that came with the T56 is straight), or some combo of the above. Most of the parts I needed for the conversioin came off the donor 1999 Camaro. I will need a bracket for the hydraulic clutch, which doesn't come off the 1999. Best price I've found is the DSE unit from Rick's Camaros.
http://www.rickscamaros.com/camaro-c...1967-1969.html
I've heard that the T56 Magnum shifter location is 2 inches farther rearward than the standard T56, and with just a bent handle shifter, will fit a stock first gen Camaro. I thought Hurst had an off the shelf solution in an entire kit, depending on your needs, and should not require major modification the transmission tunel and shifter hole in a stock console, I've heard there are a few mods required, though all mods get covered with the stock console. Depending on the transmission cross member used, mods can be virtually nothing to cutting holes in the transmission tunnel so look around and call the vendor for info/support before buying.
http://www.hurst-drivelines.com/inde...d=47&Itemid=56
Also, are you planning to use mechanical clutch or Hydraulic, electronic spedometer or mechanical (may require a transmission tailshaft swap...), and don't forget about mods to the drive shaft/input shaft depending on what came out of the car.
DETONATOR - 69 Camaro RS
LS1 - T56 - Chris Alston Frame - 2" drop
G-Link Rear - 4.20 gears in 9" - Mini Tubs
Old 09-04-2011, 04:51 PM
Default T56
I have a complete Speedtech suspension front and rear, and the normal(non-magnum) T56. I believe I have the original shifter but want to buy the right package the 1st time. I sent an email to American powertrain but got no reply. I guess I should maybe call them..Thought I would get a return email from them.
Old 09-07-2011, 04:42 AM
68ZClone 68ZClone is offline
You may have to be patient with them. Took about 2 weeks to get a reply when I contacted them for a quote.
NCSU MSME 2005
1968 Camaro
350
4-speed
-under re-construction
1989 Camaro RS
Old 09-07-2011, 08:21 AM
Sieg's Avatar
Sieg Sieg is offline
Don't know if this helps you.......in my 69 Camaro I'm running a T56 Mag with Hurst Blackjack shifter and offset bracket for shift handle which locates it in the stock console position.
Hurst Drivelines has been very prompt through the entire process.
Here's the cut I had to make for vertical clearance:
The cover for the cut:
Old 09-08-2011, 07:51 PM
LarryC5 LarryC5 is offline
Sieg,
The cover plate is looking good!!!!
Larry
Old 09-16-2011, 04:35 PM
Sieg's Avatar
latzoo - Here's the finished location with console installed:
Old 09-20-2011, 12:06 PM
senor_Camaro senor_Camaro is offline
I like your set up, very clean
