Old 08-20-2011, 09:24 PM
69blackwhss 69blackwhss is offline
Exclamation Wheel alignment problem!!! Help
Heys guys,
I don't know if this is the rite place for this r not. If not let me know an I'll try there.. I have a 69 Camaro with 17 inch wheels an when I have it wheel alignment done they use stock numbers! An I wear the front tires out way to fast, the wheels ride on the inside of the tires an I need new tires now an I still have like 60% life left on them!! Does anyone know what numbers to put for the wheel alignment? They guys said if I had numbers to use they would do it but If not then they got to use stock numbers to alignment by! So any help would be great guys am tried of buy front tires befor I need to.
Thanks jason
Old 08-20-2011, 10:13 PM
70rs's Avatar
70rs 70rs is offline
Might try the chassis and suspension section. Try a search for alignment suggestions.
Also post your questions there. You may get a faster response.
Good luck, I hope it gets resolved soon.
Eric
Old 08-21-2011, 07:11 AM
Rick D's Avatar
Rick D Rick D is offline
Like Eric said try doing a search, but also you may want to list what has been done to the front suspension like stock sub frame with what control arms. The more info you give in your auestion the better and more accurate respones you with get. Good luck.
Rick
