Old 08-23-2011, 10:09 AM
pro66tour's Avatar
pro66tour pro66tour is offline
Default Need some input...
Hope all is well...
I'm looking for a set of starter wheels for my '66 Chevelle as I begin the project. Came across a clean set of 17 x 8.5 with the 4.75 GM bolt pattern. It's got a 4" backspacing...am I good to pull the trigger on these? What size spacer would I require if any. They're coming off a GMC Senoma.
Thanks in advance...
J
Old 08-23-2011, 01:39 PM
JustinB's Avatar
JustinB JustinB is offline
Fronts will be sticking out the side of the car. 4" BS on a 8.5 is not near enough. A spacer would make the problem worse by pushing the wheel further out.
Justin Butler
69 Camaro, 68 Camaro, 05 GTO.
Old 08-23-2011, 02:20 PM
pro66tour's Avatar
Thanks for the reply Justin...Could you refer a (proper sizing) starter set-up for me, so I may clear the new disc brake set-up? Looking for a basic/classic torque thrust or similar wheel.
Once again...Thanks!
Old 08-23-2011, 10:23 PM
instro84's Avatar
instro84 instro84 is offline
sent you a pm.
Old 08-29-2011, 11:15 AM
pro66tour's Avatar
Any one else with a starter set of 17+" rims/tires for my '66? Got to get the new 4wheel disc conversion started....
Old 08-30-2011, 11:13 AM
pro66tour's Avatar
Anyone?
