Closed Thread
Old 08-23-2011, 02:07 PM
gearheadmatt gearheadmatt is offline
Default 86 Regal T. AFX spindles, 9" rear, lots of goodies
Howdy folks. Noob here with a car for sale.
Its an 86 Regal with extensive mods for the twisties. Bought 4 years ago as a straight line car for $6500. Paint & interior unchanged. Front to rear suspension and drivetrain all new bag-o-tricks.
Body:
All original. No rust. Right rear quarter was hit by previous owners wife on a dirt bike, damage was minor. Originally a V6 granny car, bronze.
Previous owner stripped interior, windows, everything for prep before spraying. They did it so its not perfect but not bad. All new window seals and swapped in good glass. All moldings either NOS GN black or painted black. NOS 87 GN grille. NOS GN black locks & door handles.
Interior:
Complete out of Turbo T including front bucket seats, rear seat, center console and steering column without shifter. Gauges include Autometer 5" tach and Sportcomp Fuel press, Oil press, Water temp, Vacuum, and AFR.
4 point harnesses, new headliner and carpet with paint.
new window motors last winter.
Suspension: Front
AFX spindles, C6 vette z51 calipers, DBA 4000 13.5" rotors
AFCO 800lb springs, adjustable spring perches
Carrera shocks, new moog steering components
SPC adjustable upper A arms w/spherical bushings new moog ball joints
Stock lowers, new moog ball joints, AFCO steel bushings
info on AFX spindles found at SCandC.com or t56kit.com.
Supension: Rear
UMI upper and lower double adjustable control arms w/roto joints
AFCO 175lb springs, adjustable spring perches
Carrera shocks
NEW: approx 300-500 miles on build since finished
Engine: 383
.30 over 4 bolt 010 block. Procomp aluminum heads
Aluminum roller rockers 1.5 ratio
Comp nitride coated custom cam and matched lifters
Scat cast crank, pink rods, flat top hyperutectic
Edelbrock dual plane RPM intake: black
Fabbed alum valve covers: black
Alternator: black
MSD pro billet and 6AL box w/timing adjust
[B]Dynoed[B] at 366rwhp, 416 rwtq at 5300ft
plummed with NOS but never run thru this motor
Trans: TH400 same as behind old motor just new parts listed below
9.5" 3200 stall converter
B&M aluminum deep pan
Rear end: new motor fraggeded the 10 bolt first time out soo...
Fabbed G-body 9" from Quick Performance
adjustable lower control arm mounts
spherical bushings in ears
billet new style big bearing housing ends
jack pad
powder coated black
Strange nodular center section
billet 1350 yoke
aluminum daytona support
Detroit True Trac
31 spline Moser Axles
Right Stuff 11.5" disc brake kit
I've got right around $24-25K invested. Going to flight school. Asking $9500
Closed Thread
