Old 08-26-2011, 12:38 PM
JUSTANOVA JUSTANOVA is offline
Default thumbsup for Ironworks
I just wanted to share another good experience from a supporting vendor.
I ordered my 2nd ls1 ecu bracket from ironworks and both times it was a quick easy and painless transaction, I dropped Rodger a pm on here, he gave me the info, I made a payment on paypal and bam! 2days later the part arrived. If Rodger is this attentive on little stuff I can only imagine what its like to have him do a full chassis or something.
Oh and the ecu bracked is gorgeous and simple. and fits perfectly. Keep up the good work Ironworks
Project EARTHQUAKE:
72 Nova SS, Plans have changed a little:artmorrison front subframe, and rear 3 link, pretty much stock ls1 and six speed with a single turbo for around 550hp. with a few other things mixed in.
current cruiser: "The green machine"
'70 Impala 4drht, 26K original miles, 2" drop springs and large swaybars, drives pretty good for a land yahct
and why do we modify everything...."BECAUSE STOCK SUCKS"
Old 08-26-2011, 01:50 PM
scherp69's Avatar
scherp69 scherp69 is offline
Have to agree with you on that one. I've also ordered two ECU brackets from the boys at Ironworks. I dealt with Brian this time and Roger last time. The last bracket was for a MAST ECU which I changed my mind on. This time, I ordered an ECU bracket and had them do up a couple custom pieces as well as a bracket for a Highway 22 wiring harness kit. As I expected, the products turned out great. Thanks again guys.
Mike
Pro Touring 68 Acadian(Nova)
Prodigy Bar rear suspension
Wilwood 12.2" brakes
New Gen Splitters
LS3 and TKO600
Old 08-26-2011, 02:30 PM
ErikLS2's Avatar
ErikLS2 ErikLS2 is offline
Same here, I've ordered some XRP plumbing stuff from Rodger and it came very quickly. It was probably more of a hassle for him than anything but he never made me feel like that and just got it right out.
Don't know if I'll ever need any of the big stuff he does but you can bet I will suggest him to as many people as I can.
Erik
69 Camaro
