Old 08-27-2011, 08:35 PM
Ivan Vella Ivan Vella is offline
Default Vac pump
G'day everyone,
I was wondering if someone can explain to me how to plumb a vac pump system with an oil separator on a boosted wet sumped SBC as well as provide vacuum for the brake booster.
It is to go into a procharged 400ci SBC Camaro that will have 6 piston fronts 4 piston rears activated by a 90deg dual 8" 1" master pedal combo from kugell komponents.
My main concerns are:
1.The evacuation of sump and rocker area pressure from the motor
2.Once the above is set up does the vac line for the brakes come off the intake manifold as usual because the motor will now have vacuum?
3.Is it possible to use an alternator off a diesel motor that has a vac pump built on the back of it would this supply enough vacuum?
(I'm trying to limit the accessories off the crank AC,Alt,Pwr steer,Vac pump etc.)
Any help would be greatly appreciated.
Ivan
