Closed Thread
Old 08-30-2011, 06:17 PM
fxstdale fxstdale is offline
Default 1972 BBC nova
asking $14000.00
Rust free body from South Carolina with laser straight body 100 percent rust free, manual brakes and steering. Car was built with all new parts never fired or finished. I have sold the BBC engine and priorities have changed. Everything was done with the idea of being able to put it back to stock easily and does come with a title. Has drums on front and rear never got around to swapping them out and no idea on condition. Front fenders were painted a little darker (highway orange) and I have correct paint for them.
Body:
Hugger orange paint is base clear. All metal is factory on the car except for the 2 inch Harwood bolt on cowl hood car, new black vinyl top. Bottom of car is done and painted black, Interior is black with new carpet. 16 gallon fuel cell with dual fuel filters and plumbed with all Aeroquip, electric fan with Aluminum radiator. BBC frame stands with solid motor mounts. Fiberglass seats with covers, 5 point harness, trunk floor has a 10x10 section cut out for the fuel cell sump.
Suspension:
All new bushings front and rear with new factory rate leaf springs, rear shocks moved inward, stock mounts still there. Competition engineering parts include drag shocks front and rear, 6 point roll cage, bolt in sub frame connectors, lift bars and aluminum body mounts with moroso trick front springs for BBC,
Electrical:
Battery is mounted in the trunk all cables run and wired. Full autometer gauges, shift light, msd 6AL with 2 step, line lock, trans brake switch wired in.
Drivetrain:
Again no motor comes with the car and is set up for a big block Chevy.
Ford 9 inch factory width, strange 31 spline axles, lightweight full spool with 4:10 Richmond gears, ½ inch wheel studs
Tci Turbo 400 with manual reverse valve body and Trans brake, scatter shield, Hughes 4000 stall converter, Hurst quarter stick shifter
Hooker super comp 2 ¼ ceramic coated headers
Weld 15 inch draglite’s, 8 inch rear 4 inch on fronts, Hoosier QuickTime dot pro 28 x 11.5 rear, 165’s on front
All parts on this car are new car has always been stored indoors I have a ton of money in this car and can get more pics, the ones posted are older and are of this car I just need some time to get it dug out. I am out of town a lot working and will respond as soon as I can, pics will take a couple of days to send though.
I have factory bumpers, grill and 99 percent of the factory parts to assemble. will sell without wheels, trans and headers if desired.
Closed Thread
