Old 08-30-2011, 08:26 PM
FP69's Avatar
FP69 FP69 is offline
Default Front Spring question...
I have a stock suspension 69 camaro that I placed 1" drop springs on that did nothing to drop the car, a local shop cut a half or more of coil out that has now dropped the car way to far over the wheel, I need to get the 3/4" back....any ideas?
The I placed 1" lowering blocks in the back but because of this guys suggestion the front needs to come back up!
Old 08-30-2011, 08:46 PM
70rs's Avatar
70rs 70rs is offline
SC&C has a front coil adjuster kit.
Edit: I see it for G body and second gens, but not first gens. Give them a call. I'm sure they have something.
Eric
Old 08-30-2011, 08:55 PM
FP69's Avatar
Thank you!
Old 08-30-2011, 09:23 PM
70rs's Avatar
Originally Posted by Frank Palmeri View Post
Thank you!
No problem. I think it will come down to spring diameter and whether or not they will fit your spring pockets. Good luck, let me know what you find out.
Eric
Old 08-31-2011, 06:05 AM
FP69's Avatar
Have you used those twist in coil spring adjusters?
Old 08-31-2011, 06:46 AM
70rs's Avatar
No. Not on any car I owned. I don't know how safe those are.
Eric
Old 08-31-2011, 07:45 AM
Track Junky's Avatar
Call Global West Suspensions and ask for a set of their Polyurethane lower control arm spring bases. They have a pocket for the cut portion of the spring and will raise front approximately 1 to 1 1/4"
I'm not 100% sure they will work with stock lower control arms but its worth a try to call and ask.
Gaetano Cosentino
Old 09-02-2011, 05:34 AM
FP69's Avatar
will do... thanks
Old 09-04-2011, 10:03 AM
David Pozzi's Avatar
Global west sells a thinner aluminum spacer that fits in the spring seat. You need a 3/8" thick spacer to raise the front 3/4".
http://www.PozziRacing.com
