Old 09-02-2011, 08:13 AM
Denvervet's Avatar
Denvervet Denvervet is offline
Default Wiring Accel inputs
I'm doing the final wiring of my project and Accel Gen 7 unit. Does anyone know how the AC /auxillary input is supposed to be wired...12 or ground? The instructions don't mention it....not user friendly obviously.
68 camaro, 572, tko
Old 09-02-2011, 06:54 PM
supremeefi supremeefi is offline
Are you talking about the A/C clutch interruption and feed forward?
Virtually all the accessory stuff are grounds, not power.
I'm an Accel EMIC, if you need help just email me at [email protected]. I'll still put it's driveability against anything in it's class, period.
Thanks and good luck.
Mark
Old 09-04-2011, 08:53 AM
Denvervet's Avatar
Mark,
Thanks for the help on this. Are the fan outputs then also grounding rather than power. Accel's using the term "energizes" the lead makes me think 12v.......not grounds.
David
68 camaro, 572, tko
Old 09-04-2011, 09:06 AM
camcojb camcojb is online now
Mark,
David
the fan outputs should be grounds for the relays. The computers usually do their controls through grounding. Hopefully he will verify this, but all the ones I've done were grounds.
Old 09-04-2011, 01:49 PM
Denvervet's Avatar
Thanks. Makes sense....now I will move on. All the wiring of the car is starting to make smoke come out my ears
68 camaro, 572, tko
Old 09-06-2011, 10:09 AM
Correct.
Old 09-06-2011, 12:55 PM
Originally Posted by supremeefi View Post
Correct.
thanks Mark.
Old 09-09-2011, 04:24 PM
Anytime.
Mark
Engine builder and tuner.
