Old 09-02-2011, 08:26 AM
cspecken cspecken is offline
Default I need a set of Small Block Chevy frame mounts for my LS conversion
I am looking for 283-327 Small Block Chevy frame mounts / engine stands for my 1964 GTO LS Conversion project.
Thanks Chris
Old 09-02-2011, 10:18 AM
64skylarkls1 64skylarkls1 is offline
I'm doing an LS conversion in my 64 Skylark, I believe it's same frame as yours. I rebuilt the LS clamshells and fabricated my own frame mounts so I could get the car as far back and as low as possible. It worked for me.
Old 09-02-2011, 05:28 PM
I would assume that the frames should be similar for a 64 Buick and 64 Pontiac . Do you have any pics? I just figured the 64-67 SB Chevy mounts is what others have used and it appears to have worked. Most of the engine adapters that I have been looking at call for the SB Chevy frame mounts.
Chris
Thanks Chris
Old 09-03-2011, 01:12 PM
No longer need, bought a set today.
Thanks Chris
Old 09-03-2011, 03:24 PM
Sorry Chris, I looked though my pics and didn't have any of the mounts. I had planned on taking some tomorrow for you but sounds like I'm too late.
What are your plans for engine exhaust? Headers? Manifolds? I'm using the LS1 manifolds from the 02 donor car. It's a little tight on the pass side and the drivers side need a new location for the sensor but I got it figured out. I know other guys have done that too.
Good luck on the build, sounds like a great project.
Gene
