Old 09-07-2011, 06:42 PM
tonyvol tonyvol is offline
Default Ride Tech Tru Turn for a 67 - 69 Camaro
Hey everyone, has anyone used Ride Tech's Tru Turn system for a 67 - 69 Camaro? I wondering what you guys think of it. I wondering how it compares to L & H or AFX spindles?
Thanks,
Tony
Old 09-07-2011, 09:50 PM
Blake Foster's Avatar
it is a different approach, than using the AFX spindle. i have talked with ridetech about seeing how the AFX spindle will work in conjunction. we currently have a compatible steering arm it is just a matter of getting all the parts in one room and measuring.
we have already sold a few but have had no reports back. for what that's worth
Blake Foster
www.speedtechperformance.com
Old 09-07-2011, 09:51 PM
spacepirate spacepirate is offline
Have you looked on Pro-Touring.com yet? They have a build thread going right now.
Old 10-27-2011, 10:35 AM
bret's Avatar
bret bret is offline
Supporting Vendor
Tru Turn compatibility evaluation
In response to many requests to determine the compatibility of our new Tru Turn system with other manufacturer’s suspension components, we have gathered and evaluated some fitment and geometry data for the following combinations.
We realize fully that this does not cover all the possible combinations. It ONLY evaluates the most likely [and requested] combinations of the Tru Turn system with other manufacturers components. We did not evaluate any aftermarket combinations with the oem Camaro steering arm because it’s length and position typically prevents the use of the wider 10” width wheel, which has been a primary requirement of most customers.
It is very important to note that we have NOT evaluated other manufacturer’s COMPLETE systems. It is very possible that their complete systems will generate better geometry data than some of the [unintended] combinations we put together below.
THAT IS WHY WE STRONGLY RECOMMEND THAT YOU USE A COMPLETE ENGINEERED AND COMPATIBLE SYSTEM INSTEAD OF TRYING TO PIECE TOGETHER A SUSPENSION SYSTEM FROM SCRATCH!!
Most manufacturers should be able to give you this level of geometry evaluation on their own suspension systems.
Data summary:
Example A – This is a OEM spindle with an OEM steering arm…just like GM delivered it. The camber curve is nearly nonexistent, meaning that the tire will NOT lean into the turn as we would like. The toe variation @ .600” of toe IN during compression and total change @ .720” are both excessive.
Example B – This is the complete Tru Turn system as we engineered it, and as we would deliver it to a customer. The Tru Turn system shows 2.9 degrees of camber gain at a 2.5” compression position. It also shows a toe variation of only .070” [slightly over 1/16"] toe out and a total toe change of only .110” [less than 1/8"].
Example C – Substituting the SpeedTech ATS aluminum spindle within the Tru Turn system changes the camber curve little, but seems to make a dramatic increase in both max toe variation @ .540” and total toe change @ .800”.
Example D – Substituting the Heidt’s spindle in the Tru Turn system created geometry similar to example C only with even more toe variation and change.
Example E – Substituting the Heidt’s control arms for the RideTech arms did not significantly alter the geometry from example D.
Example F – Shimming the outer tie rod DOWN by .750” made a huge improvement. Max toe variation was .250”, and total toe change was .450”
Overall summary
These examples DO NOT tell us that other manufacturer’s components or systems are neccessarily inferior to the Tru Turn system. Instead they tell us that just because certain components will bolt up together, it does not necessarily mean that they will function properly together. Yes, your car will likely go down the road just fine for many years. No, a mismatched combination of parts will not offer “just as good” of handling performance as a complete system.
All the aftermarket examples showed a similar and significant improvement in camber gain. The differences seemed to be in the bumpsteer measurements. Bumpsteer is radically affected by the precise location of the various steering components. Different manufacturers will use slightly different locations for these components. When used as intended [as a complete system] they will achieve the intended goals. When combined with other [unknown] components, the end result may coincidently bolt together, but may not achieve the geometry that was originally intended.
Here is a link to more infomation on the complete Tru Turn system:
http://www.ridetech.com/store/muscle...r/tru-turn-en/
You will notice that there is some variation in the toe change data from this test to the info published on our website. This is because a bit different alignment settings were used that day...AND because it is quite difficult to measure toe to 3 decimal points over a 5 foot length.
Bret Voelkel
President
RideTech
Air Ride Technologies, Inc.
Old 10-27-2011, 12:06 PM
Bryce Bryce is offline
Data summary:
Overall summary
Nice write up!
Old 11-06-2011, 02:31 PM
ccm399 ccm399 is offline
Awesome info Bret!
Thanks for posting the results. Your honesty is very much appreciated. (Your link to the Ride Tech page is broken though)
http://www.ridetech.com/store/suspen...ents/tru-turn/ Is this the correct page?
Chris
Checkout my '71 Pontiac Firebird Build Thread Click Here
Old 11-06-2011, 08:15 PM
coolwelder62's Avatar
You cant go wrong with Ride Tech's fine product's .Scott M.(Ride Tech Dealer)
