Go Back   Lateral-g Forums > Vendor Specific Technical Discussions and Support > Roadster Shop Chassis and Components
Old 09-13-2011, 02:17 PM
RS-Chris's Avatar
RS-Chris RS-Chris is offline
Supporting Vendor
Default FAST TRACK '62-67 Nova Chassis
Turn your Chevy Nova into the ultimate corner carving machine with the new Fast Track Chassis System from the Roadster Shop.
The CNC cut fully boxed frame rails eliminate flex and twisting commonly seen in factory Nova’s. The Fast Track IFS incorporates modern components such as a new power rack & pinion, C6 Corvette spindles, Z06 hubs, and splined sway bars to insure you stay ahead of the competition. The narrow chassis design allows for a 10” wide front wheel and 275 series tire along with a staggering 12” wide rear wheel and 345 tire.
The center cross-member is designed to accommodate a full 3” exhaust system while maintaining the lowest ride height in the industry (4”-6” ride height). A heavy duty 9”rear-end and 31 spline axles will be delivering the power out back, pair that up with a performance 4-link rear suspension or the optional watts link for the ultimate pro-touring experience. As with all our Muscle car chassis, the Nova is upgradable to the IRS rear.
Standard Features
  • RS Fast Track Front Suspension utilizing proprietary geometry
  • C6 Corvette spindle and Z06 hub assembly
  • Adjustable Afco billet coilovers
  • 1.25" splined front sway bar with C6 Corvette end links
  • Custom fabricated, fully boxed, 10 gage frame rails
  • Utilizes all stock body mounting locations, bumper and core support mounts
  • Lowered ride height
  • Engine mounts for SBC, BBC, or optional LS Motors
  • Custom center crossmember with adjustable, drop out trans mount
  • Mid brace crossmember with exhaust ports for up to 3" exhaust
  • HD Ford 9" housing with 31 spline axles
  • Large diameter triangulated 4-bar rear suspension
Pricing and Info - http://www.roadstershop.com/products...k-nova-chassis
Old 12-04-2011, 05:36 PM
michael6372 michael6372 is offline
Is this the chassis used on the Runt Chevy II built by RPM?
Michael Scheuren
www.streetmachinecentral.com
