Old 09-17-2011, 02:35 PM
DutchSS DutchSS is offline
Default Procharger D-1sc
Hi guys, i am currently running a 509 with 10,5 cr in my camaro and would like to boost it with 5 or 6 psi. I can buy a used D-1sc. Wil this work on my engine ? I know the D-1sc is a bit small, but I am not looking for high boost.
Old 09-18-2011, 07:59 PM
big_G's Avatar
big_G big_G is offline
Not too small. It will be just fine. I would, however, be wary of running boost with that compression. An intercooler is mandatory in your case, IMO.
Old 09-19-2011, 11:28 AM
Thanks for your reply. I am thinking of converting to E85. If not I am gone run it on C14 or C16. Its for dragracing.
Old 10-03-2011, 06:58 PM
bski224 bski224 is offline
Thats a fine size unit. I would MOST DEF run an Intercooler and E85 with that CR. Its a time bomb!!! but lots of fun!!
Old 10-03-2011, 09:55 PM
bigtime's Avatar
bigtime bigtime is offline
is this going to be EFI or blow thru? EFi your gonna want a intercooler for sure, blow thru you can get away with a little more.
Bob
Old 10-16-2011, 04:39 AM
Blow through, I am in contact with CSU and C&S. Any thoughts about that ?
Old 10-17-2011, 02:26 PM
Jr's Avatar
Jr Jr is offline
Dutch,
I'm no supercharger expert, but I think that D-1 will be too small for your 500+ ci motor. Usually guys with 346-402 ci motors run a D-1. You may want to look into an f-1 for you application. Also, I have only read good dealings with CSU.
