Old 09-18-2011, 06:18 AM
dill68 dill68 is offline
Default 17 or 18
is there any advantage of one over the other? i like the more sidewall of the 17.going to order forgeline wheels monday. just seeing what everybody thought
Old 09-18-2011, 06:44 AM
If i assume you own a 68.. 18's look better in the well.
18 is more common these days so their are alot of tire options.
17 can give you more sidewall which can be a better ride..
I would go with 18 beacuase i am willing to sacrifice some ride quality for the tucked tire look... i have a real big problem with the look of a tire that doesn't fill the wheel well.
Old 09-18-2011, 06:56 AM
these tires will be going on my 67. the outside dia will be the same 335-30-18 vs 335-35-17. only difference will be height of sidewall
Old 09-18-2011, 08:52 AM
go 18 if you can on rear.
Old 09-18-2011, 10:12 AM
Sieg's Avatar
Sieg Sieg is offline
Brake caliper clearance can be an issue on 17's depending on your plans.
