Old 09-18-2011, 08:01 AM
Bryan O's Avatar
Bryan O Bryan O is offline
Default AAW LED indicator lights wiring help needed
I am doing the wiring of my AAW 1969 Camaro Update kit and I need some help.
Any suggestions on how to incorporate the ground for the LED indicator lights into the guage wiring scheme?
The indicators are all 12V. The gauge of the indicators is higher than that for the rest of the wiring. Probably 20guage vs 18guage.
I figure I can daisy chain the indicators together with the ground for the gauges. But, that seems rather cumbersome and doesn't help much to organize the wiring.
Here's a picture from the front of the dash insert showing the LEDs.
Here's a picture of their wires and the overall wiring of the gauges as it exists now. The loose black ground wire is the wire I could use to daisy chain the LEDs to.
Here are copies of the AAW wiring scheme directions. The left turn signal is pictured on the left. The right turn signal on the right and the high beam is second from the left. I am not using a brake indicator.
Any help would be greatly appreciated.
Thanks!
Bryan
Project Alchemy
https://lateral-g.net/forums/showthread.php4?t=29820
Old 09-19-2011, 05:55 AM
fletcherscustoms fletcherscustoms is offline
You can daisy chain all the grounds together.
Here are some pics of a DSE dash with 9 gauges I am wrapping up for a customer. I used a American Autowire gauge cluster harness setup for Autometer guages. ITs a little different than the std Camaro harness but as far as wiring it, its all the same.
Chad Fletcher
Fletcher's Customs and Speed
229-221-4690
[email protected]
Old 09-19-2011, 10:52 AM
64pontiac 64pontiac is offline
I agree...... The grounds can tie in with the gauge ground that comes from the dash harness connector. Even though they are different gauge, just tee them together with the gauge grounds and solder the joints...... making a daisy chain harness.
Tyler
HPI Customs
Manitoba, Canada
www.hpicustoms.com
Old 09-23-2011, 06:28 PM
Bryan O's Avatar
Thanks guys! We managed to get the gauges wired but we couldn't solder the larger gauge wires from the LEDs. So, we doubled them over and crimped them to the smaller gauge wires using butt splices. Then we heatshrinked them. I think they'll work and hold.
Bryan
Project Alchemy
Old 09-23-2011, 11:45 PM
canrc canrc is offline
Looks good Chad!
_________________________
- Raj
'69 Camaro - Current Project
https://lateral-g.net/forums/show...ighlight=MAX-G
