Old 09-19-2011, 06:04 PM
WicKeD_SS's Avatar
WicKeD_SS WicKeD_SS is offline
Default Paint for Rear Body Pan?
Im not sure what people are using for the flat black on the rear body panel. Is there a PPG paint or something I need to order. Wasnt sure what was the right paint to use to prevent stains from gas or wax.
-Brian
WicKeD
Old 09-19-2011, 10:09 PM
Rick D's Avatar
Rick D Rick D is offline
-Brian
Nothing will help with wax, if you use wax on semi-gloss or flat it will start to shine up. I would use a mat clear coat over black base coat. Any paint company will work but I would stay away from the chepo stuff, go with a name brand as it will hold up better. I use Sikkens but PPG will work. When waxing either keep the wax away from that area or mask it off so you don't get the edges to start shining up. Some will say a rally black it's a single stage paint will work and it will give you the LOOK you want but not the UV protection and will not help with gas and other solivents they will go right through it. Good luck
Rick
Last edited by Rick D; 09-19-2011 at 10:12 PM. Reason: more info and I need a speak and spell
Old 09-20-2011, 06:15 PM
WicKeD_SS's Avatar
Thanks thats what I was looking for. Car is getting painted this weekend and really needed to find the best way to paint it. Ill just pick up some PPG.
Thanks again!
WicKeD
