Old 09-20-2011, 03:47 PM
dave96dcm dave96dcm is offline
Default Need anything laser cut?
I'm not the salesman, but I do run the laser at NEFM.com and we are kinda slow right now, it might not be worth it for the backyard builder, because I think our shop minimum is in the $150 to $200 neighborhood, but if you need a small production run please let us know, I cut aluminum from .007 to .250 thick, stainless from .020 to .375 and steel from .010 to .50 thick, we have alot of materials in stock and have numerous places we use for plating and powdercoating if you are interested in that.
Old 09-22-2011, 08:29 AM
BanditDave BanditDave is offline
Hey there,
I will be in touch with you about a project I am working on...thanks!
Dave
Old 09-22-2011, 08:33 PM
Grnova's Avatar
Grnova Grnova is offline
I may have a bracket or 2 I need cut out of a piece of 1/4" aluminum.
Tim
Old 09-24-2011, 05:26 PM
We can do that, .250 T6? Thick aluminum sometimes has a little bit of slag on the bottom but it easily comes right off, if you want it complicated keep in mind that the laser uses a circular pierce so the pierce is about .100 diameter it makes it difficult to do small holes and typically it is difficult to do holes that are smaller diameter than half the material thickness.
Old 09-25-2011, 05:57 PM
RECOVERY ROOM's Avatar
Supporting Vendor
RecoveryRoomInteriors.com
PM sent
TRACY WEAVER
www.recoveryroominteriors.com
Old 09-25-2011, 06:43 PM
Replied
Old 09-30-2011, 06:30 PM
Anyone else need anything?
Old 10-12-2011, 05:53 AM
We are in the process of coming up with a quote for one company so far. If anyone is interested please don't hesitate to ask.
