Old 09-22-2011, 07:32 AM
67ragtp 67ragtp is offline
Default installing an Oil cooler
Been researching oil coolers, temps in the 270 to 280 are a bit more than I want to see for a sustaned time. If anyone has any pics or suggestions on a neat way to mount the heat exchanger in a 69 camaro, would really like to see it. My plans are to use either a 625 or 634 Setrab with a Motec AOTGM thermostatic controled oil cooler adapter. The adapter bolts to the side of the engine block removing the take off plate, its pretty cool that gm built cooler provisions in to the ls blocks. Anyone using it?
Rich
