Old 09-26-2011, 11:45 AM
Swiftshifter68 Swiftshifter68 is offline
Default SB Ford 1994 Lightning 351W roller motor, intake to pan, 440hp, 420lb-ft, MSD too...
1994 351W motor, roller shortblock, in excellent, running shape, pulled to change drivetrain setups completely.
Pic's here:
http://www.norcal1320.com/forums/sho...p?t=1191201514
1994 351 Windsor Roller Motor
Victor Jr. Heads w/ Scorpion Roller Rockers
ARP Head Studs
Black powdercoated Ford Motorsports Valve Covers
Super Victor 351W Intake
Trick Flow hydraulic roller blower grind, Adv. 292*/290*, .542"/.563"
High Volume Oil Pump
High Flow Water Pump
MSD Pro Billet distributor
MSD BTM Ignition Box
MSD Blaster SS Coil
MSD Two Step
Front Sump Oil Pump with bung welded in for blower drain
Motor setup has about 500miles on it. Just selling because I?m completely changing my drive train setup to bigger and badder. $4500 Takes the Long Block Intake to Oil Pan Plus all the ignition Parts.
Greg
(530) 339-2093
Old 09-26-2011, 12:51 PM
PM sent
Old 10-03-2011, 04:56 PM
Originally Posted by DriverzInc View Post
PM sent
Tried to send pm. Box is full. Call greg 5303392093 for more info.
