Old 09-26-2011, 07:32 PM
tkz69camaro tkz69camaro is offline
Default Backspace
I sure could use some help with getting the backspace right on a 69 camaro. The front wheels will be 18x8 with 245/40/18 and back will be 18x9 with 275/40/18. Tires will be nitto 555. The car may be lowered 1" but no more than that. The measurements in the rear are 5 1/8" from hub to fender lip, 6 11/16" from hub to frame rail. If someone could tell me the width of the tire when it's mounted I think I could figure the backspace out or if someone is running this setup that would be great. Thanks for your help you can give me and thanks for your time.
Old 09-27-2011, 11:23 AM
Give us a call, we'll be able to help you, its pretty cookie cutter...
Old 11-11-2011, 04:48 PM
pragmatist pragmatist is offline
Use this as a general guideline.
http://www.rimsntires.com/specs.jsp
Old 12-15-2011, 01:14 AM
tandk22 tandk22 is offline
My hankook 275/40 18's have tread width of 9.4" and a select width (widest point of the side wall) of 10.9" on a 9.5" rim. On your 9" rim your tire should be a little less. Todd
