Old 09-27-2011, 04:48 PM
NAPA 68 NAPA 68 is offline
Default What does the wire get connected to?
I am wrapping up my LS1 conversion in my 59 Bel Air, and I am puzzled by one wire. It is a purple 16 ga. wire that is in the harness that goes down by the crank sensor and starter. It is terminated with a 3/16 ring terminal on it. BTW, this is a GM Performance wiring harness / ECM #12480113. This appears to be the only item that is not marked. Does it go on the starter? Ground? (Can't imagine that due to it's purple color)
In advance, thanks!
Tim
Old 09-27-2011, 08:26 PM
camcojb camcojb is offline
In advance, thanks!
Tim
that's the starter crank wire from the ignition switch.
