Old 10-05-2011, 06:11 PM
brownz brownz is offline
Default any pointers on mini tub install?
I will be installing mini tubes in my 79 camaro and would like to know if any of you have any suggestions of what to look for during the install, I did get the DVD so I hope that helps lol
Thanks in advance
Old 10-06-2011, 07:21 AM
ma73z's Avatar
ma73z ma73z is offline
I did my first set of tubs on my 73 a while back, it wasn't a bad job just take your time and don't cut off to much.
I would recommend after you make your marks to use a plasma, die grinder or whatever to get a large portion of it out of the way and then make your final (more precise) cuts. Basically just take your time follow the instructions and watch the dvd you'll be good.
