Old 10-08-2011, 07:13 PM
rsimons rsimons is offline
Default What T56 x-member with Wayne Due subframe
I have a Wayne Due C4 subframe in my 67 Firebird. I'm wondering if there is a trans crossmember that will fit for a T56. The width from frame rail to frame rail is 31" which is narrower than stock. I appreciate anyone's advice on this. Thanks.
Old 10-09-2011, 04:10 PM
We always make a custom tube one so the exhaust fits, but you can always buy a generic one from chassis works, cpp, http://www.classicperform.com/Store/.../XMCA67697.htm etc it should fit with little modification.
Jeff Allen
J2 Speed and Custom
Old 10-09-2011, 04:28 PM
Thanks for the advice. That one would have to be narrowed. It looks like the Heidts crossmember may mount similarly to the Wayne Due.
Old 10-09-2011, 09:07 PM
Vince@Meanstreets's Avatar
The last one I did we used a 70 Camaro crossmember, chopped the mount plate and rewelded it lower on the cross member. The outer crossmember mounting flanges are long enough so we just redrilled a few holes.
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 10-09-2011, 10:11 PM
Lenie's Avatar
Lenie Lenie is offline
http://www.cachassisworks.com/Attach...brs_DS_WEB.pdf
Lenie
Old 10-10-2011, 02:14 PM
Z06vette's Avatar
Z06vette Z06vette is offline
Default X member
I usd the BMR cross member for a OD automatic. I shaved the ends of the flat metal mounting area but still used origianl holes & just drilled holes where needed on the wayne due mounting surface. Can take pics if needed.
69 RS LS3/T56
68 firebird vert LS1/4L60E
67 RS LS2/T56
