Old 10-10-2011, 05:48 PM
John510's Avatar
John510 John510 is offline
Default Help deciding which center section to buy
My car is a T56 LS3 with a Fab 9 rear and 19x12's. Has a Texas Speed 231/236 cam installed.
I am confised on which center section I should order. Iron or Aluminum? Which brand is best? Id like it to be able to hold some power as eventually it will get a Kenne Bell.
Also, what gear ratio would you guys recommend? 4:10 or 3:73?
Thanks for the help
[SIGPIC][/SIGPIC]
Old 10-10-2011, 11:02 PM
funcars funcars is offline
Cast iron is much stiffer than aluminum and resists deflection better. With drag racing the case deflection is tougher on gear contact patterns and cast iron may be the longer gear life approach. Road racing isn't usually quite as brtutal on the cases and gears seem to live longer with an aluminum case.
If you have mega torque and huge ultra sticky tires the choice is pretty obvious.
1970 Mach I 380 Dry Sump + lots of mods
1990 C4 Corvette 400 in solid roller
1965 Corvette - back to life some day
1970 1/2 Z28 project car
Old 10-11-2011, 08:27 PM
TheJDMan's Avatar
TheJDMan TheJDMan is offline
This guy sells rebuilt 9" center sections in your choice of gear ratios for not a lot of money.
http://cgi.ebay.com/ebaymotors/FORD-...item4cfac67073
Steve Hayes
"Dust Off"
68 Camaro
"Jeremy Clarkson"
Old 10-12-2011, 11:59 AM
bulletpruf bulletpruf is offline
X2.
The only reason to run aluminum is to save weight, but it's not much. Maybe 10 pounds? Iron is stronger and a lot cheaper, too.
As for the gear ratio, google "gear ratio analyzer" for something online. Plug in your trans gears, tire size, and rear end ratios to see what it does to your rpm.
Old 10-12-2011, 01:13 PM
Ron in SoCal's Avatar
Scott - IIRC, my aluminum cover was 1/2 the weight and about 15 - 17lb savings according to Moser...
Ron in SoCal
69 Camaro in progress
Old 10-12-2011, 01:25 PM
intocarss's Avatar
In my drag car, I ran both the N case and the Moser through bolt alum cases. I never saw a difference in gear wear and we checked that stuff pretty regulary and my car was 3050# and made 1000Hp JMOHO
