Old 10-11-2011, 11:13 AM
chevyman722 chevyman722 is offline
Default L18 8.1 Vortec 96 Impala SS
Hey
Im new to this forum but i have seen some nice projects on here. I need a bit of advise. I built an 8.1 Vortech and going to put it in an 96 Impala SS. The problem i have run into so far it the motor mount on the crossmember is staggered but it is not on the engine. Should I just drill new holes in th x-member?
Old 10-11-2011, 11:26 AM
camcojb camcojb is offline
Originally Posted by chevyman722 View Post
Hey
if the mounts are staggered or offset to one side, that's usually done to make clearance for something like the steering box, exhaust, etc. If an LT1 came out of there then a big block should bolt to the same mounts/pads. That doesn't mean it will clear everything though, the big block is much wider than the LT1, oil pan clearance maybe an issue, etc. But as far as bolting in you should be able to take the LT1 mounts, bolt them to the big block, and have it line up with the frame pads. The mount pad on the block of a small block, LT1, and big block are the same.
Welcome to the site.
Old 10-12-2011, 11:07 AM
street3285 street3285 is offline
Welcome to the site! SOunds like an awesome project your working on, and I have always loved the 94-96 Impala SS cars.
Post up some pictures.... would be great to see your project.
Travis
