Old 10-12-2011, 07:00 PM
marks914's Avatar
marks914 marks914 is offline
Regular User
Default GEN II 70-78 Camaro gauge mounting solutions from New Vintage
As promised, here is the GENII 70-78 Camaro gauge mounting solution we have been working on. The package mounts 2 3-3/8” gauges and 4 2-1/16” gauges in the stock location, retaining the stock turn signals switches and dash panel. The laser-cut and formed mount bolts to the factory mounting screws. The bracket is formed to follow the countour of the original dash.
The only thing left to do is find a donor vehicle to test fitment and decide what to do with the stock shift indicator area. We have considered using one of our indicator panels in there to fill the void. Looking for input there.
Thanks, look foreword to any input
Mark
Pricing for the basic mount should be around $100.00
www.newvintageusa.com
Old 10-20-2011, 05:01 AM
marks914's Avatar
Regular User
Ay interest at all or should we drop this one?
Old 10-20-2011, 02:17 PM
skatinjay27's Avatar
have you checked the interest on nastyz28 ? on a pro-touring site i dont think this will move much because honestly the stock gauge panel looks dated in a pt build.
AJ
Old 10-20-2011, 03:43 PM
djorgensen3 djorgensen3 is offline
Default gauge panel
Yes definitely try NastyZ and also Team Camaro. You should have a lot of interest on both of those sites. You might also be asked if you have, or will have, anything available for the later 2nd gen dash.
Old 10-20-2011, 09:11 PM
BonzoHansen's Avatar
BonzoHansen BonzoHansen is offline
Try nastyZ28. I think that looks great.
Scott from NJ
Old 10-21-2011, 10:00 AM
marks914's Avatar
Regular User
Thanks guys,
just to let you know this is not a stock replacemet but a mount to install our aftermarket and custom gauges in the stock location. That way you can keep the stock plate that actually fits and retain the controls. You can run any of our 3-3/8 and 2-1/16" gauges.
Ill have to se what it takes to be a sponsor over there
Mark
Old 10-21-2011, 01:45 PM
1976camaroguy's Avatar
1976camaroguy 1976camaroguy is offline
I like it, mostly because I am working on a 5.3 swap in my 1976 camaro and could benefit from something like that.
Right now I plan on using factory guages and a cable x controller to convert the signal to my stock cable driven speedomenter.
Is there anyway you could make the shifter opening accept the stock shifter indicator? Looks like there is plenty of room. I'm am using a 4L60e in my car and have already bought the OD shifter adapter kit with the center mount indicator.
I would like to try and keep that if all possible
1971 Camaro Pro-touring LS engine
Old 10-21-2011, 03:32 PM
Default interest
Well I threw a link on nastyz to this thread. Check out the interest over there in only few hours.
http://www.nastyz28.com/forum/showthread.php?t=226139
Old 10-21-2011, 08:17 PM
70rs's Avatar
70rs 70rs is offline
YES......please make this. And in the shift indicator area put blinkers (one above the other, arrows) a neutral light, a high beam light and park brake light.
I will buy one when they are ready. And gauges too.
Thanks jorgensen, I found the link on nastyz.
Eric
Old 10-23-2011, 07:14 AM
marks914's Avatar
Regular User
Hi Guys,
I think that the stock shift indicator can be installed or we can install a custom indicator panel:
Right now the hold up is we need to get a car in our shp for final fitment.
