Old 10-15-2011, 01:06 PM
Xplosive Performance's Avatar
Xplosive Performance Xplosive Performance is offline
Default Wilwood Brakes 6 Piston Direct Bolt on 65-82 Corvette Front Replacement Caliper Kit
The D8-6 caliper is a direct bolt-on replacement for the factory original calipers on all 1965-82 Corvette's. Forged billet aluminum bodies, stainless steel pistons and competition style high-temperature seals put an end to the rust, bore pitting and seal failures that plague the OE caliper design. D8-4 calipers provide low-maintenance performance and a huge weight savings with high temperature reliability for the street and track. D8-6 calipers mount in the stock location over stock rotors, and use the original style OE D8 brake pads. Calipers can be used with any wheel that clears the OE calipers. The factory piston sizes were duplicated to maintain the original front to rear brake bias and use of the OE master cylinder. Kits contain DOT compliant stainless steel braided brake lines with BP-10 high friction pads.
http://www.xplosiveperformance.com/65-82-Corvette-D8-6-Front-Replacement-Caliper-Kit-Clear-Anodize_p_2266.html
http://www.xplosiveperformance.com/Brake-Kits_c_5672.html
ALSO AVAILABLE IN BLACK OR RED POWDERCOAT
CALL TOLL FREE
888.493.8041
PM
FREE SHIPPING
Bob Brown
XP Motorsports LLC.
Xplosive Performance Inc.
[email protected]
AIM: CH3NO2fun
