Old 10-16-2011, 07:06 AM
Xplosive Performance's Avatar
Xplosive Performance Xplosive Performance is offline
Default Motul RBF600 is the best high-temperature Brake Fluid
Do you track your car
Do you drive it hard
Do you feel soft of spongy brake pedal
Then you need
Motul RBF600 is the best high-temperature Brake Fluid and preferred by many tuners and race teams. Its specifications and labratory results exceed that of DOT 5 silcone based fluid, but still retains the benefits of Glycol based fluid by lubricating the ABS pump and not deteriorating caliper and Master cylinder seals
100% Synthetic Brake and Clutch fluid. Compatible with all Dot 3 and 4 fluids. Specifically designed to resist the high temperatures of actuated (steel or carbon) racing brakes and clutch systems.
Don't trust your high performance car to just any brake fluid
http://www.xplosiveperformance.com/M...00-_p_648.html
Call Toll Free
888.493.8041
PM
Order Online
Bob Brown
XP Motorsports LLC.
Xplosive Performance Inc.
[email protected]
AIM: CH3NO2fun
