Old 10-16-2011, 04:58 PM
lomchivok lomchivok is offline
Default 70 pontiacYU350 with #62 heads
Got a 70 Pontiac 350 YU block..a good runner with #11 heads. Have a set of #62 4bbl heads with 2.11 and 1.77 valves with 72cc chambers. I know the comp will be high with today's pump gas but figure a thicker head gasket may get the ratio down enough.
Will there be a problem with the big valve heads on this 350 block as far as the valves contacting the block...What cam would you recommend?
thanks in advanced...
Old 10-18-2011, 09:31 AM
takid455 takid455 is offline
compression would be fine. I run 62's on 400's. 455 w/ 62's creates an issue.
Dont know what car or what your goals are to select cam. budget? roller / flat tappet
the old H-O racing HC-02 (RA3/ 71 -72 HO ) would be nice. a touch on the aggressive side for a350 but manageable.
need more info . prob best to talk to cam manuf or place you were to buy the cam. Just dont get a chevy cam. will cost more, but worth it.
Old 10-21-2011, 08:30 PM
Sorry, I was kinda vague...
Looking for something in the 285 duration advertised range & 460 ish lift that will allow me to use my stock turbo 350's torque converter.
It'll be a weekender street cruiser regular driver but not daily
Flat tappet in a 67 firebird with a fresh 70 pontiac 350 bored 030 over with surfaced not shaved heads & a turbo 350 stock converter...B&M shift kit
