Old 10-16-2011, 06:36 PM
Roadster Shop's Avatar
Supporting Vendor
RoadsterShop.com
Default eGarage 1969 Camaro
Ben, of eGarage.com has teamed up with Nelson Racing Engines and the Roadster Shop to take the eGarage Camaro to the next level. The goal is to add much needed strength to the car to handle the monster 2,000 HP 572 twin turbo engine built by Tom Nelson. A custom Roadster Shop chassis was designed to add strength and rigidity to the car along with an integrated roll cage. Suspension will be our Fast Track IFS and IRS sporting Penske remote reservoir coilovers and Brembo brakes at all 4 corners. The car will be undergoing a complete mechanical transformation from the chassis to cooling system, to turbo and intercooler systems, to complete fuel system, and then some.
Build videos and interviews will be up soon on eGarage.com. In the mean time, check out their site for their truly unique and inspiring take on portraying collector, exotic, and custom cars; the owners, the builders, and the stories behind them.
As the car rolled in.
A work of mechanical art under the hood.
www.roadstershop.com
Old 10-16-2011, 06:37 PM
Supporting Vendor
RoadsterShop.com
Disassembly begins:
Old 10-16-2011, 06:43 PM
Supporting Vendor
RoadsterShop.com
After analyzing the car and the build, it was decided that a custom perimiter chassis would be the best approach. The decision was made to widen the platform and build a chassis that would go out to the rocker panels. This would add strength and allow the body and the roll cage to be tied directly into the chassis. In order to do this, the stock floors would have to go.
The car was braced and the stock floor was then cut out.
Old 10-16-2011, 08:01 PM
northwests's Avatar
northwests northwests is offline
cant wait to see whats in store!
Old 10-16-2011, 08:23 PM
pokey64's Avatar
pokey64 pokey64 is offline
Wow, that thing is nuts!
//Ed
//1964 Impala SS
//1966 Chevelle (Family Hauler)
//1969 Camaro (Hers...)
Old 10-16-2011, 10:02 PM
HotRod68Camaro's Avatar
HotRod68Camaro HotRod68Camaro is offline
Definitely subscribed to this one.
Kyle
Old 10-16-2011, 10:47 PM
Kendall Burleson Kendall Burleson is offline
A very cool project by RS more pics
Old 10-17-2011, 06:38 AM
dave96dcm dave96dcm is offline
What is the product that you are using to cover the outside paint? I can see that it is 3M but I dunno what it is.
Old 10-17-2011, 08:03 AM
Rick D's Avatar
Rick D Rick D is offline
3M 5916 weld spark paper, it has a self adhesive backing take look here.
http://3mcollision.com/3m-welding-an...per-05916.html
Also another awsome car by RS
Rick
Old 10-17-2011, 04:52 PM
Supporting Vendor
RoadsterShop.com
Thanks everyone. This should be a pretty cool build and we are excited to be a part of it.
Rick, you got the 3M paper correct. It works very well on a painted car to protect it from sparks and paint damage while working on the car.
