Old 10-26-2011, 06:47 AM
usa-69z usa-69z is offline
Default Identify this tremec please???
http://www.ebay.com.au/itm/280759809...84.m1438.l2649
this link above is for an ebay ad in australia ,, Looking at the pics it seems to be a little different to other tremecs? the shaft on the top is exposed where others i look at seem different..I want to purchase this box but want to make sure.. can some-one help please?
thew VE R8 is the high performance commodore here in oz , 2009 model .
thanx!
69 CAMARO - RIGHT HAND DRIVE AUSSIE MODEL.
383 SBC 8 STACK INJECTED EFI.
RIDETECH FOUR LINK REAR - DSE MINI TUBS .
SPEEDTECH FRONT A ARMS & COILOVERS.
MOSER 3.7 REAR- 6 SPEED T56 TREMEC.
FIKSE RIMS ETC ETC..
Old 10-27-2011, 09:25 AM
Matt@BOS's Avatar
Matt@BOS Matt@BOS is offline
Looks similar to, and may be a Tremec TR6060. Some people liken them to an oem equivalent of a T56 Magnum. The shifter location on these transmissions is set very far back, unlike the Magnum. Aside from the shifter location being moved maybe four inches closer to the driver, you may have difficulty getting it to work with the remote shifter because of the height of said shift mechanism.
Matt
Old 10-27-2011, 03:40 PM
Matt
thanx Matt , thats what i have discovered after i posted this,, i think it is a TR6060 and way too much work to fit in my 69... I just picked up a t56 tremec so it will all work out now .. thanx for the condirmation !
Gav
