Old 10-29-2011, 01:40 PM
MaxHarvard's Avatar
Default 9" outer bearing binding issue
Everything is brand new, although when I try to snug down the drivers side brake bracket, the outer bearing seizes and will not allow for any more movement.
Any thoughts?
The right side works just fine, no binding issue at all.
Old 10-30-2011, 07:44 PM
70rs's Avatar
70rs 70rs is offline
Bigger hammer?
Wish I could help Eric. Maybe contact the brake kit mfgr, see if anyone else has had similar issues?
Eric
Old 10-30-2011, 09:22 PM
TheJDMan's Avatar
TheJDMan TheJDMan is offline
Maybe some pics?
Steve Hayes
"Dust Off"
68 Camaro
"Jeremy Clarkson"
Old 10-31-2011, 09:58 AM
MaxHarvard's Avatar
Well, turns out that the shaft was too long.
I called the rear-end guys and they told me to cut 1/8th to 1/4" off the end.
Seems to have done the trick. I used my chop saw and a grinder.
Nothing major and it went in just fine
