Old 11-04-2011, 08:15 AM
samckitt's Avatar
samckitt samckitt is offline
Default GM stock bell housing for LS2/T56 magnum?
I was told I could use a late model GTO bell housing with LS7 clutch/flywheel. Anyone confirm this works? If so, what throw out bearing?
Thanks,
Scot
Scot
86 Monte SS
LS2/T56 Magnum
Old 12-27-2011, 06:56 PM
HRD's Avatar
HRD HRD is offline
bump for a reply. I also need to know this.
Old 12-29-2011, 06:55 PM
GeoffP GeoffP is offline
I think the GTO and the F-body bell are the same depth flange to flange. Assuming this is true and the fact that the LS3/LS7 clutch works just fine in 98-02 F-bodies in theory it should work just fine.
GeoffP
68 Camaro LS1 T56 3.55 12 bolt posi
